Looky looky its a girl :D
**runs and hides behind shane**
its not confirmed, but the rumors are she is a girl :ninja:
damn straight i am!
*does a jig*
u forgot this ==========> ;)
ive been here since 7, and i doubt ill be out of here b4 9! :P
its not catastrophic.. his tyre rubbed up against my rear bar, but its the principle, plus it looked WAY worse when i saw his car hit mine ;) theres paint missing but the fibreglass is as far as i can tell intact.
bit like my rear bar, the paint came off it, but it still white underneath, u can hardly tell, my paint actually exploded when i did it. it was all over the place.
need me to stab someone?
:P
yes please, incompitent people i work with and this farking computer, it decided to erase half my design this arvo and i've been stuffing around fixing it up!
sigh, just stab me ;)
ha ha i just remember when i went to willowbank about 2 weekends ago, these random chicks near the ipswich turn off in a barina, came up beside me and my mates in his starion which is bright orange, they yelled out "show us you dicks"!!
We were like WTF rofl so funny lol
Yep it was a good day today!
Everything I needed I managed to find with no hassles and I got my job application in on time....and it was shit hawt
awesome work...i woulda slept most the day ;)
did u oblige? ;)
Well did you show them?
I cant sleep in any more, If I go to bed at 5am I will still wake up at about 7am
sigh, just stab me :P
but i dun wanna stab YOU
i wanna stab OTHER PEOPLES ;)
just let me know when and where :ninja:
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
