haha
I've been looking for a user who has > 5 tags. Jay had 5 at one time and Marc has 5 now...but I wanna find one with 6 or more
ha ha ha
in teh wasteland i saw a dude with them on his av listing his shopping list :wave:
5 is the max i've seen to...
and only one person hase multiple clubs... (i think it was anna)
hmmm what does everyone think of 3000gt's/gto's?
they are alright i guess...
why are you thinking of changing to one of them?? man i've seen some with bits off a NSX looked very sexy...
selling the is200 i might have a buyer for you at the right price... $20,000
(O) (O) <---- Man Boobs for Matt
