I'm just over the media hype of what has been an issue for a fair while. 'Ice is the new Marijuana'. It's not the new marijana you cocks, as that would imply people are using one more than the other. They love to pick something as their 'issue of the moment' and advertise the shit out of it! *sigh* kids these days! :laugh: :laugh:
would he do it? with the split cv's?
this is my work! stfu
if its not obviously dripping all over the place, yes...he's in redbank. what u could do is, drive there, pull over just b4 and wipe any grease away :laugh: (or just wipe all the grease out of there and replace it short after its complete)
it's called MULTI-TASKING....
oh... wait... sorry... that's a term only females are familiar with
:laugh:
ha ha ha
*waits excitedly in the corner biting nails for the wrath to begin!*
hahah "its all in the head" <======== this applies to you, young anna :laugh:
ha ha ha
sif there be a shit fight over that.... every one know women can multi task.... its about doing many things half arseidly (sp) we men can only do one thing at a time but we do it good and proper.......
:wave::huh::O:laugh::laugh:
bahahahaha touche!!!
best comeback by a stooge ever!!
jokes :laugh:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
