:mad:
OMG shane, thanks so much for the angry mountain bum sex,folding my clothes, washing up the dishes and kissing me good bye this morning, you made me feel like a princess again.
dont you just love those emails saying to wear protection when your having bum sex?
Nah, i dont get them :)
just stick to the lubed condoms and we will see dude.
i aint promising anything anymore.
:D:( makes me wanna cry :(
if u could feel my pain, you'd understand.
lets cry together John, my penis is alwyays therr for you.
OMG whore town has gone down hill :D
dude
u come any closer to me
and i`ll have shane onto you for the lovin u cry for!
sorry bryn, jess has me booked out all of this month, maybe next month?
:D
I have work tomorrow. Hooray! That's one less day i'll be sitting around home bored out of my brain!
hooray! doin what?
answer the home phone
u forgot the...:mad:
P.S that wasnt a kiss on ur cheek this morning bryn :)
come on now lee, ud bang ugly betty
:D
you know the Chick that playes Ugly Betty isn't ugly at all...
man this temp is UGLY *brrr.. Cold Shivers all over* she's looking at me again..... *Brrr.....* :mad:
you should of come temp for us at tafe...
instead of the fat mole i'm stuck with....
fark shes UGLY!!!
Awwwww *pats
Anna i just Added you to my MSN do block me now :mad:
I'm not on MSN. I'm about to go have a nap.
Betty is still pretty rank. We saw pics of her at some awards show and she's still a little ummm... 'unsavoury' :D
Betty is still pretty rank. We saw pics of her at some awards show and she's still a little ummm... 'unsavoury' :)
Lets put it this way....
she makes America Ferrera Look like a farking goddess...
when she glances my way i wanna :D
:mad: i'm not being mean shes just so farking gross :D
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
