nah, i'll need to get overnight parts from japan :)
talking about that....
just cos i put Domokun as a my real name people have been refering to me as Dom.....
man it makes me feel like a big bald white dude that lives my life a Quater mile at a time ;)
man it makes me feel like a big bald white dude that lives my life a Quater mile at a time :O
lol yeah i've seen a few ppl do that! lol
plus that phd thing :no:
hey loosers! cant stay have to work!
just dropped in to show u guys this:
http://i135.photobucket.com/albums/q140/dr...O/DSC00146b.jpg
cya all saturday!
ps if anyone has done this before please let me know! lol
http://www.skylinesaustralia.com/forums/in...howtopic=157179
cya all saturday!
crapy photo......
sorry Zennon cant help you could just yank it till it opens.... or find the end or the cable and yank really hard...
cya all saturday!
what i usually do is, reach down under the dash and pull the relase catch...oh urs is borken, im so sorry zennon :O
you do know that lxu55 will be the car that gets most attention. sad seeing its a sau thing.
only caus its going to be the only one that throws a rod out of bed :no:
my girl wants to party all the time...........
no wories zennon :O
seriously though, i think ur gonna have trouble getting at the latch, unless u pull the whole front end apart. if the front of ur bonnet didnt come down as far, u'd be able to get to the latch, but yeah good luck :no:
Im having the same problem with my boot, it all works perfect, but when u pull the lever it doesnt pop, (only about 15% of the time) do i assume i need to get new gas struts?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
