this also for sale
1992 Toyota Aristo V (Lexus GS300), 3.0 litre twin turbo sedan (JZS147 2JZ-GTE 3.0 litre with 208kW)
Automatic
77,560 kms
Wine red (colour change from black)
MASSIVE GReddy T88-33D full turbo kit with external wastegate and aftermarket exhaust manifold
Very thick front mount intercooler
Full aftermarket bodykit including front spoiler, sideskirts, rear spoiler, and lower door panels
17" aftermarket alloy wheels
OHLINS coilover suspension
Aftermarket twin exhaust
ALPINE DVD / navigation system (requires conversion to work in Aust.)
Aftermarket white steering wheel
Lots of other aftermarket parts
Cloth interior
Cruise control
Auto tilt-away steering wheel
All power options and airconditioning
Condition notes: Colour change is quite good, and all door jams etc. have been painted. Minor front repair -- noted as front bumper only. Body is in very good condition. Looks like a drift car from a distance but in reality it appears to have been very well looked after. The kms appear genuine and the engine sounds fresh. The aftermarket exhaust is larger than the original but in the opinion of the supplier is not large enough to suit the T88 turbo and could do with upgrading to get the most out of it. The white steering wheel is not very nice and should be replaced. Other than these things, the car is great.
$16,300 estimated in australia
Edited by 85URK
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
