you guys need to watch that movie "kids" its the most screwed up movie.
Ahaha I was just reading about that. Apparently this 'she's too young' is a remake of kids, but it has been done in a way that is more educational and witty than kids. And this is about syphilis. Kids was about HIV yes?
OMG I saw one of those on an Ignition DVD, they had the full set up in an Evo. It's exxy but I think it's worth it!!!
they are not as expensive as you think, and i rang qld transport about it and they said that they were fine to use in a street car.
That's excellent! You can chose which guages and shit you want displayed, hey? Or am I thinking of a different one ;)
yep thats the one, works out slightly more expensive than buying all the gauges i want.
Ahahah i'm trying to make Andrew swap computers and then get the dash replacement cos I think it's funkeh! And you've got everything you need right at your fingertips.
Bahahahahahaha ;)
Nah Karen, one day I was at home sick last year, I was watching this movie on TV, and later that evening was talking about it in whoretown. Turns out Joshwa had been watching the same movie. It's basically about a bunch of 14 year olds that are 'trying before buying' and having lots of sex with random 20 year old guys. One gets syphilis, they all get syphilis, and basically there's an outbreak in the school of 14 year old girls with syphilis. One part in the movie, the school nurse asks this girl how many guys she's slept with, and she pauses for a long time. The nurse says 'it's okay, you can tell me - I won't tell your parents', and the young girl replies 'nah it's okay, i'm still counting' ;):rofl:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
