*sings*
DRADLE DRADLE DRADLE! I MADE U OUT OF CLAY!
DRADLE DRADLE DRADLE! TOGETHER WE WILL PLAY!!!!!!!
Holy shit son... andy busts out in song every so often with that EXACT song. It's so annoying!!!
dunno, somethin to do with bandwidth goin through the roof over the past few months (which is right, a 23% increase more then this time last year).
dont know when they`ll bring it in but its being talked about.
maybe they should look at upgrading the switches, caus its jsut getting beyond rediculous. 100mb switch in brisbane here, srwp or horizon gets a 1gb switch!!!!
yet they are going to spend rediculous money on upgrading to vista? stupid farks :(
all sites need to recoup the cost for the switch's before they can upgrade.
SRWP is a new site and opted to pay the additional cost for the 1gig network as they r a project, not run/own by who we work for.
and we aren't upgradin to vista.
i heard they were seriously thinking about it, and also upgrading the computeres again
how many switches are in birssy u know? apparantly the difference in price is 5k a switch (14 port or something)
awww whys that love?
why's?
Well i've been sitting at home all week, and i've been heaps excited about going out this weekend at the Coast with people we haven't seen for a while. Last night went shopping and got new clothes, jewellery, and was heaps excited about it (the top is haaaawt!), anyway we get home and find out that something's come up and we can't go anymore :( So now i'm all emo cos I haven't been out in months and was really looking forward to it *sigh
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
