oh so charming anna.
:thumbsup::laugh:
It goes with out saying...plus I dont need to make them molest you they do it of thier own free will
IT all depends....I could be nice and make nice ones molest you but in all honesty I will probably sick the Nanna on to you
ZOMG that old lady... I swear to god she's a cop!
How funny was that cock an balls chicken suit!
CHICKEN SUITS FTW!!!
I am still laughin actually...........
Can you not post gay emos up on the page, it is really off putting, and that should be saved for a google search if your into it...
100 cool points for your mum
cool, and i'll order you a "punchintheface" :thumbsup:
Emo’s aren’t gay, they are bi. They need to swing both ways to double their chances, or create some form of chance to began with :thumbsup:
Emo’s aren’t gay, they are bi. They need to swing both ways to double their chances, or create some form of chance to began with :laugh:
oh yes SORRY!!! my bad.
emo---------> :thumbsup: <---- normal
