OH NO YOU DI'NT!!!!
She is the ONLY chick that can pull of tats and still look farking amazing!!!
more pics please :D then i will give you my verdict,
i could just be jeolousy... has more tatts thatn me :(
This message is to advise you that your account on http://www.boostcruising.com has been modified. We support a “warn system” which provides you 5 chances before your account is terminated.
Your current level is : 20%
Some examples of unwelcome content are:
· Excessive abuse language,
· Posting of explicit images,
· Hoax or nuisance posting in “For Sale” sections,
· Abuse of other Boostcruising members,
· Promotion of off topic material in any section other than “Off Topic”,
· Giving the public a poor perception of the Boostcruising name,
· Abusing privileges such as IRC and Email.
If you have any questions regarding the current status of your account, please contact the Moderator that carried out the changes either by email or a forum private message.
Moderator: angels666
Regards,
Boostcruising Staff
I've come to a realisation angel666 is Sarina Russo.....
they both are fat and ugly and both slept their way to high powered postions....
true story...
be all the s**t you can be.....
Please quote what was wrong, before I take this further.
Thank you
The reasons were in the original PM
Please re-read :(
They are the boost cruising rules, which you have copied. Fair enough, you are a moderator. However, I am asking as to what exactly was said and or done to receive the warm, which I am entitled to know.
I believe there is some biased opinion and miss use of moderator powers in this case, unless other wise you can show
Thank you.
Edited by Nismo_Boy
BAHAHAHAHAHAHAHA
MOD REVIEW YESSSSSSSSSSSSSSS!!!!
They are so lame and ugly
lol... come join the club lovie.....
and they never take you off it :( creat a new acount almost exactly the same as your first.... it'll freak them out....
I really couldn't be bothered... ha ha ha
I still talk to who I want to from that site, that's all that matters...
P.s. Hi Jamie :D :D
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
