I am cruising to the airport later tonight..
Ah that ok anna.....f**ken shit drivers on my way.
and a q for everyone..
...what do i use to put one of the skyline pics in my sig....the littles ones you colour yourself etc.
those little ones that some people have
KICkKICk KICkKICkKICkKICk
KICkKICkv KICkKICkKICk
KICkKICkKI KICkKICkKICk
KICkKICkKICkKICkKICkKICk
KICkKICkKICkKIKICkKICk
KICkKICkKICkKICkv
KICkKICkKICkKICk
KICkKICkKICk
KICkKICkKICk
KICkKICkKICkKICk
KICkKICkKICkKICkKK
KICkKICkKICk KICkKICkKICk
bored much-K is for kick!
KICkKICkKICkKICkv
KICkKICkKICkKICk
KICkKICkKICk
KICkKICkKICk
KICkKICkKICkKICk
KICkKICkKICkKICkKK
H IS FOR HOMER!!!!!!!!!!!!!!!!!!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
