Nah he's a boy! lol
Should seen my last fight mr ahmed poor bugger couldnt walk for over a week and that was with shin guards...fun times!
Do you do trix on him :glare:
Yeah I bet, I havent seen those fights in person, but pics and movies say nothing but ouch. I have no effort nor the persistence to learn anything remotely close.
Edited by Mr Kofi Ahmed
Hahaha Josh is finding hes black roots, BMW??
Long story short, I bought one last year, but gave it to dad to cover personal debt and then gave/sold him the Lexus this week to cover my credit card debt, which I bought the BMW on, god I suck at money management.
