p.s., best thing abotu whoretown is that you can come and not read anybody elses previous posts and just say what u want.. plus im bored at work and just feel like ranting somewhere..
I like pie.
I like pie too..
someone tell me why i only pulled 160rwkw on the dyno =\
FMIC, 3" turbo back exhaust, Pod Filter, Cold air intakes, Boost set to 12 psi, SAFC2 tuned. i was hoping for 180-190.. much disappointed :happy: It was on Matt Spry's dyno, which i know reads a little low, but was still expecting to hit 175-180 on it..
One thing that may provide some clues (tho im not sure how). When we did a run on the dyno with the SAFC2 zero'd, the AFR's were much higher than would be expeced from a stock ECU running 12PSI.. (like, A:F in the 13's)...
we ended up tuning the SAFC to PLUS 5-10% air so it richened up the mixture more.. isn't it normally the other way around. And if so, what would cause the car to run lean like that ? Could it be the reason why im not seeing the power i should ?
GO WHORETOWN TO THE RESCUE
Yes I've been browsing the C&H site... but could this be the Plough Inn?
the crazy thing was that I kept screaming out "some B*tch got shanked!* and me and Anna kept yelling out that "bring the vaseline and the straight razors"
bahahaha
We didn't even know :happy:
Hahaha I can see you guys doing this:
home made or McDonald's?
Home made ftw
I like pie too..
I wouldn't have thought that figure was all that bad... maybe a little bit low but not awful? Lean AFR's could point to dodgy fuel pump, blocked fuel line, fuel filter that needs replacing etc, or possible the AFM reading wrong.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
