Looking forward to the move??
yes and no. Will be good to have my own place with my own things - up till now i've lived with other ppl.
I must admit i will miss everyone ive known over the years at different places working/travelling - i've covered most of qld, most of them i will never see again. I fear i will get bored in one place but at least i'm there for only 12 months.
