me sponser you? rofl i can barely sponsor myself :(
i thoroughly agree! everyone has gone soft, but we shouldnt talk about it caus we mite get warned :dry:
i wish it was legally alrite to go round and shoot all the faries and nancies in this world!
lol Numbnuts, you'd have to shoot yourself first :(
U know it! Tomorrow is pretty much my last day.. Friday nothing productive will be going on LOL
I'll be saying bye to everyone all day!
awesome! :dry:
dont forget that really long lunch break :(
ha ha ha yeah to the restaurant/PUB down the road :(
haha and many a drinks!
speaking of pubs and drinks, i can wait til friday, head to the RE at 12:30 and start drinking til 5, then head up to the regatta and keep drinking til ~7, all paid by work :(:dry:
ha ha ha yeah to the restaurant/PUB down the road :dry:
speaking of lunch.. just had a foot long steak sub.. was yummy..
for ten bucks you can get 2 x foot longs + 1 x med drink.. got a coupon for it.. so i got today and tomorrows lunch for 10 bucks... cant argue that
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
