sick as a dog....
moved yet Anna Banana?
i see no dinner tonight i fink the week end hurt my pocket badly....
:blush: dam 20% surcharges.....
Negatory, my dad's real sick and is having an operation, so it's looking like the end of the month/early May now.. :)
good babes how bout u? :)
yeah i'm gettin there, was hard coming into work this morning after a 4 day weekend :ermm:
P.S where were u last tuesday nite for dinner bish? huh huh??? :(
sick as a dog....
:) dam 20% surcharges.....
sick as a dog aye, gonna roll over and die? :blush:
yeah i'm gettin there, was hard coming into work this morning after a 4 day weekend :)
P.S where were u last tuesday nite for dinner bish? huh huh??? :blush:
ha ha ha yeah tell me bout it!!
I was absent cos I stayed back at work :(
There is no Tues night din din tonight?
I was absent cos I stayed back at work :blush:
hmm dunno if that's a good enough excuse...
nothing's posted so i dont think there's gonna be one organised
hey Shane, go take a long walk off a short peir.....
man i couldn't go to dinner even if there was one.... no moneys.. lol and i really shouldn't be soreading my sickness around :blush:
but i am at work and infecting everyone...
hey lee, go have a drink of STFU :)
its not rebuild #3, its just a minor hiccup,
and that reminds me, i have to go and pick up the bits of my gearbox.
fark off, a light hone doesn't count as a "minor hiccup" :blush: maybe a "technical malfunction" or even a "minor fu*kup" :)
what did it end up costing ya?
well go with a minor f*&k up on the part of an outside party, and cost isnt the issue
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
