Of coarse its funny, its a f**king EA lol
Nah his behaviour that night shits me off, its people like him who f**k up our mountian's. Get in, have fun and get out. Not go up be a tool and crash and let the whole world know what we do
Love it! Just think of the new's coverage
Yeah right! I can just see the headlines now...!DIRTY OLD MAN KIDNAPS YOUTH AND STEALS FAMILY PORSCHE!...Parents are frantic....Reward offered for return of Porsche :laughing-smiley-014:
Id say your on the mark with the last part
the 2nd (which i'll pickup when i give him the rest of the mula) is a cf bride fixed back bucket
both seats were weighed, the cobra (above) wieghed in at just over 6kg's, and the bride just over 7kg's (the bride has a custom 1/2 side mount rail made of alloy)
noice bud. It looks featherweight. :D
certainly is! next weight reduction is to remove the abs :P
oh also have my bonnet dramas sorted :action-smiley-069:
If you have not already sold the stockers let me know Shane
sold them aaages ago sorry big fella
Noel baby look what im watching today
Movie: THELMA & LOUISE
Broadcast Date: Friday 11 May 2007
Channel: Free to Air / 7 Central
Broadcast Time: 12.00 pm
Classifications: Movie, ® (CC) (1991) M (V,L)
Timeslot Duration: 180 mins
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
