So what box are you going to go...how much power are you intending to make? The os giken and ppg gearsets have been used in some pretty high hp cars that do regular track days. You aren't going to go with something dog engagement are you, talk about spending your weekends stripping down your box to check everything out after a day at the track....no thanks.
800bhp is what i've speced everything else to, but prolly be lucky to make 750bhp. i know theres some pretty decent hp cars usin the os kits, but then theres just as many people who have broken os kits. Also from what i've seen you only strip down a dog box after a year of racing, just to check it then.
I dont know, from what I researched when I was looking at boxes, dog boxes are very high maintenece, especially if driven on the street as they don't select gears well. Also unless you opt for billet selectors they have an even shorter life span. I am pretty sure SydneyKid was saying they strip their boxs after almost every race meet as it's necessary to check for problem components...and iirc he was talking about how they had to replace items rather regulary as they started to wear down. I think they are perfect for track only cars, but a bit of a problem for street driven cars.
periodic maintenance far outweighs the need for a complete replacement if u do smash an os set, @~5k for a ready to go os 5speed
plus theres the likelyhood of this gtr becoming a track only car, i can see it happening
From a back yard car to a track only car. Thats quite a contrast :domokun:
From a back yard car to a track only car. Thats quite a contrast :P
you like? :domokun:
P.S eat a dick fanboy
http://www.skylinesaustralia.com/forums/in...c=159419&hl
there's a more recent article on the ppg dog boxes....
yeah i read that, and i aint goin ppg lol, i've seen 1 ppg break, and whitnessed issues with another on the weekend (the later bein a 2 weekend old box, the other a 2 yr old box)
all I can say is I can't wait to see and go for a ride in your car once its finished Shane!!
i'll be the first to say it...youll be waitin a while lol. the engine's nearing finish time and startup, but theres the suspension side and braking side i gotta take care of before i go spastic with driving it in anger
all good things take time....or lots of money.
you know you can drive when you can drive with a dog box too....good bragging rights :P
that and coupled with a super light twin setup :P
Im looking foward to racing it :)
it'll be interesting to see indeed!
i would say u'd have me from down low, but seeing a result with a built 26/30 coupled with a TO4z from UK, 1bar by 3200rpm on the run in tune, i reckon i'll be on song very early! :domokun:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
