Dad, or Mum, were probably going to the airport, they always drive that to the airport because lexus gives free valet for the duration of your time away and free cleaning...they milk the services haha.
I sahll put some up later on tonight. I have to pick my GF from the airport shortly.
thats why I have been on here recently, because she has been at the APEC thing in Sydney
ahhh ok. I'd wondered why you've been on so much as of late. Truth be told, i'm hardly on here anymore either, just random luck that I logged on the other night and caught up with everyone.
got dan ordering me a new lift pump (carter) and the fuel cell filler neck. oter than that sfa
put many more dents in the 180? :D
lol u funny man.
nah last one was tyre pushed my guard underneath.. just being it back.. woot woot for .3mm sheet metal :D
So sad, a harmless joke and next thing we have people bringing out all the stops with the school yard "mum jokes"....where is the world heading?
oh come on matteh ligthen the fook up already :)
he is the guy you walk away from in a debate....cause he just keeps pulling shit out his arse to through at you otherwise.
lol ill walk on him.
hehehe wheres the love :)
with ur mum lol
geez, you're really cutting me deep with the mum jokes...surely you have something better Marki.
hows my fist sound..??
dnt worry its not just me i knw of others that arnt too fond of u. its just the world as u say
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
