thats nice, that still doesn't make it a motorsport though :)
you have your opinion and i have mine, one thing we do agree on is that you need to get your car back on the road.
ps i think im more interested in circuit racing now but ill see how that goes
agreed, too bad i dont have 20k just lying around :)
im a big fan of circuit racing, but the costs involved in having a decent go are far too high
the people who built your car, seem to think otherwise.
you might be able to use your power if you start sliding, other then that you wont be able to use it..
somehow i dont see a big laggy turbo'd setup is going to work all that well 'drifting'. nor will it work that well circuit racing, theres only 1 left that it will suit :)
sooo true...
street racing.....
rofl, i've had heaps of people call shotgun now :)
yeah but you are a nice guy...soo.....
im not sure on the turbo to run though. dan says go the gt42r, but the guys at MTQ said the GT45R would spool quicker, but flow more >_<
i dont see how a smaller turbo will flow more...or a bigger turbo will spool quicker.....i suppsed the rear house size would make the different to a certain extent.
details?
rebuilt w/ turboport and race seals
microtech
gt35r w 1.06 housing
800cc primaries and 1600cc secondaries
frount mount
ext gate no screamer
its the one that made 365hp on 14psi, its now getting tuned to run 22psi and c21
microtech
frount mount
mmm tasty!
microtech
frount mount
B..B...B...b..b..bloody hell....secondaries?? do i need to research rotors a bit more.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
