thats nice, that still doesn't make it a motorsport though :)
you have your opinion and i have mine, one thing we do agree on is that you need to get your car back on the road.
ps i think im more interested in circuit racing now but ill see how that goes
agreed, too bad i dont have 20k just lying around :)
im a big fan of circuit racing, but the costs involved in having a decent go are far too high
the people who built your car, seem to think otherwise.
you might be able to use your power if you start sliding, other then that you wont be able to use it..
somehow i dont see a big laggy turbo'd setup is going to work all that well 'drifting'. nor will it work that well circuit racing, theres only 1 left that it will suit :)
sooo true...
street racing.....
rofl, i've had heaps of people call shotgun now :)
yeah but you are a nice guy...soo.....
im not sure on the turbo to run though. dan says go the gt42r, but the guys at MTQ said the GT45R would spool quicker, but flow more >_<
i dont see how a smaller turbo will flow more...or a bigger turbo will spool quicker.....i suppsed the rear house size would make the different to a certain extent.
details?
rebuilt w/ turboport and race seals
microtech
gt35r w 1.06 housing
800cc primaries and 1600cc secondaries
frount mount
ext gate no screamer
its the one that made 365hp on 14psi, its now getting tuned to run 22psi and c21
microtech
frount mount
mmm tasty!
microtech
frount mount
B..B...B...b..b..bloody hell....secondaries?? do i need to research rotors a bit more.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
