yes Marki SR's are side feed too, same as RB25's...
S15 have like 470cc injectors, so it could be a cheap upgrade for an rb25, however when i was in the market it was hard to get a set of 6 as everyone wants to sell 4.
Plus for the money I was able to buy a set of 6 nismo 550cc units brand new, which was far more fitting to my application in the end...
BTW Do you have a name for that tint joint???
dnt knw.. go for a drive on logan rd down at the gabba just next to SS toyota and ABS is the tint place.. i have a feeling its called tint mart..
I think only JDM s15s have that size injector
from memory the S15 ADM is 440cc
man im just gonna go with the 740cc nismos screw the expenses.
Your a nerd mang
UR EMO
+1
ur white and a red head..
Sif Halo 3 is teh bestest game for the 1337. Halo 2 was harder.... ;)
halo 2 was a failure much like the R33 GTR compared to the 32 34 bahaha..
i find myself playin halo 1 more with mates than halo 2.. better story.. but 16person matches and 4person co op in halo 3 ftw.
my gamming doesnt go past msn uno
checkers now bitch
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
