fark IT are a bunch of twats and tossers
myspace is block
youtube is blocked
facebook is blocked
porn is blocked
guess u gotta work dont u
says the kid with 4 nationalities ;)
lol...
yo shane.. went out with that louise girl yesterday after work.. u remember the one u like :P movies tonight if i wnat.. but driftin at archy till 6.30 ill prob ditch her for mates..
lol...
yo shane.. went out with that louise girl yesterday after work.. u remember the one u like ;) movies tonight if i wnat.. but driftin at archy till 6.30 ill prob ditch her for mates..
lol uve got serious issues marki *shakes head*
anyword on noels car shane
yeh, had fueling and ebc issues yesterday (i left work at 12 to go and help mick) fixed them and this morning when mick started to tune it, the turbo oil drain line melted through. it's a teflon lined braided hose, but was resting against the manifold, so melted right through.
so now just waiting for mick to fab up a metal drain pipe for it.
asif.. im sane.. what issues u speak of..??? at least i see girls..
...melted the oil return..
u ditch these so called girls of urs to go to the drifts, like wtf man lol. josh is not a girl thank you very much ;)
yepo lol. i couldnt believe it when i got the call, sigh :P
halo 2 was a failure much like the R33 GTR compared to the 32 34 bahaha..
your ghey if you think that.
Halo CE was tops
Halo 2 was better
Halo 3 is gooder still.
da shit!!!
farken failure..crapness.
cant believe Noel's car crapped again. best of luck with it again.
hiyah girly!!
hows the car?
Not in my possession yet... but it will be soon :sorcerer:
Oh btw I tested the potato bake recipe I have last night.. DAYAM it's good.!
anna u need to update ur cars thingy in ur profile :P
better?
SICKNESS!!!!
get some drifto teks and shickness will be more like et! ye!!!
better?
muchly :glare:
Nah i'm getting Work VS XX
got dish? :D
fkn A brother! I can't decided who to go with for the stroker kit. HKS, Tomei or Jun. I'm leaning towards JUN just cos I haven't heard of anyone else using it but the HKS one is just so cheap!
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
