fark IT are a bunch of twats and tossers
myspace is block
youtube is blocked
facebook is blocked
porn is blocked
guess u gotta work dont u
says the kid with 4 nationalities ;)
lol...
yo shane.. went out with that louise girl yesterday after work.. u remember the one u like :P movies tonight if i wnat.. but driftin at archy till 6.30 ill prob ditch her for mates..
lol...
yo shane.. went out with that louise girl yesterday after work.. u remember the one u like ;) movies tonight if i wnat.. but driftin at archy till 6.30 ill prob ditch her for mates..
lol uve got serious issues marki *shakes head*
anyword on noels car shane
yeh, had fueling and ebc issues yesterday (i left work at 12 to go and help mick) fixed them and this morning when mick started to tune it, the turbo oil drain line melted through. it's a teflon lined braided hose, but was resting against the manifold, so melted right through.
so now just waiting for mick to fab up a metal drain pipe for it.
asif.. im sane.. what issues u speak of..??? at least i see girls..
...melted the oil return..
u ditch these so called girls of urs to go to the drifts, like wtf man lol. josh is not a girl thank you very much ;)
yepo lol. i couldnt believe it when i got the call, sigh :P
halo 2 was a failure much like the R33 GTR compared to the 32 34 bahaha..
your ghey if you think that.
Halo CE was tops
Halo 2 was better
Halo 3 is gooder still.
da shit!!!
farken failure..crapness.
cant believe Noel's car crapped again. best of luck with it again.
hiyah girly!!
hows the car?
Not in my possession yet... but it will be soon :sorcerer:
Oh btw I tested the potato bake recipe I have last night.. DAYAM it's good.!
anna u need to update ur cars thingy in ur profile :P
better?
SICKNESS!!!!
get some drifto teks and shickness will be more like et! ye!!!
better?
muchly :glare:
Nah i'm getting Work VS XX
got dish? :D
fkn A brother! I can't decided who to go with for the stroker kit. HKS, Tomei or Jun. I'm leaning towards JUN just cos I haven't heard of anyone else using it but the HKS one is just so cheap!
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
