ur full of poo poo marki....:P
haha was quite a weird outing.. she wore this grey dress boobs out and all.. nice rack for 17 imo
He will totally love that everyone's got him in their av LOL Anna & I might be at dinners... come to think of it yes we'll probably be there
I'm not at work bishtits. Is it important?
awwww how cruel :P i love it
be ther andy i got this airvent for ya ass
but only cos your man boobs smell of sweet sweet nectar
BAHAHAHA
But if you drive a 33 mudcrab will feel unwanted.
i feel wanted by NS.com
Mudcrab would harm himself if you drove a commo.
i would.. commos suck donkeys
whoa, mark is todays top poster :rant:
of course im resident awesome
Mark gives good head.
said ur sister... i went down on her while she had her rags... :D
Dont hate me coz I look better then barbie
barbie is hot.. at work we call rachael my date for this arvo barbie.. she giggles like a 18yo jap school girl..
short skirt too marki? caus boobs out + short skirt/dress = want sexy time haha
nah dress..
it was just below her ass
she was fine... i counted how many guys checked her out as we walked past gilhooleys.. lost count when i got evil eyed
i didnt say nything about having a gf. i was talking about having sex u fakren douchbag
dude shes hot uve seen pics of her.. but shes friggen 17 and quite annoying. hence why i took her home straight after.. i didnt even try to kiss her goodbye.. not my cuppa.. now the other girl on the other hand.. SMOKING HOT.
Nah, just do a turbo back with split, into twin 3inch open pipe. Leave it pretty stock and boring. Just have it loud :) I only want a daily driver
Gimme 18K and I'll turn it into a reliable 700rwhp daily driver ;)
Gimme 18K and I'll turn it into a reliable 700rwhp daily driver :P
Or I could buy my old R32 back with 720hp at the fly, then spend $800 on giggle gas to make 700rwhp every now an then ;)
If you can build me a 700rwhp motor for $18k though... I'm seeing you when im not poor haha. f**king rb in the S13 cost $25k and that was only 600rwhp on c16.. tame.
Lets talk 2jz's and $18k :)
it all ready has a turbo back! Shane just cries that the exhaust is actually of good quality and flows as well as being quiet!
Really? hahah It's sleeper spec!! in that case cut the mufflers out :P
yeah it has a HKS front mount too!
and for another $500 you can ave the AVCR and Exedy sports organinc I have in the garage...AVCR is the black limited edition one (used) and the clutch was never installed
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
