sup bitchtits
how was yesterdays cruise?
Yeo Bruce.
yeah man had a blast, man Tim's 33 is da shit, so stock so quite...nice sound system...no mods needed...has a sunroof.
only thing is the driving position is a bit different....had my head half out the sunroof most of the way. drives really well though. doesnt like bumpy roads though a bit low for that, but still good.
where were you yah bum!!!
had a good weekend finally installed my gauges & blue rice led cluster lights, jjr coil packs and some new cheap and nasty NGK's car is transformed it litterally is pulling like a farking freight train, my clutch is screwed now just from booting it as it starts to come onto boost the clutch starts to slip, water pump is also leaking real bad :down:
i hope u get farked over soon josh :)
P.S hi :down:
Me: excuses me, how much longer do I have to wait?
Lady: I don’t know
Me: It’s not good enough, I have been here 40 minutes, and you told me I only had too wait 15minutes.
Lady: Can you come around to the other side of the counter?
Me: How much will it cost to jump the line?
Lady: It doesn’t work like that here
Me: I don’t give a shit, how much? You told me 15 minutes; I’ve been here 40minutes. Your management sucks.
Lady: Josh, you have only been here 27minutes, do I look like a management? I can’t help that.
<centrelink room is now all attention on me>
Josh: 27minutes is not 15minutes; management needs to fix this shit.
Lady: getting angry at me wont help you in this situation, Josh.
Me: Yes it will, I have better things too do then wait f**king here.
Me: Make me an appointment at a more convenient date for me
Lady: I can do 9:30am tomorrow?
Me: Will it actually be 9:30am though?
Lady: It depends how busy everyone is.
Me: This isn’t good enough
<Walks out to the badass 911 parked out the front>
Lady: I don’t know
ha ha gold
Lady: I don’t know
Sarp foos?
Sif your not getting audited in the next fortnight Josh lol
Anyway, just thought I'd say hi before I go out and mow the grass.
Cyas.
i hope u ripped some skids leaving there!
No, 2 weeks ago I parked in a disabled car park at centrelink and I got in a fight with a rent-a-cop over it. who then called the cops. So I’ gotta be could there.
The rent-a-cop paid me out about being a “brat” and how mummy and daddy bought my car, I’m all like dude your clueless. I’m at centrelink for a reason – I’m on the dole mate.
“That would be right, nothing but a dole cheat you are”
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
