No, 2 weeks ago I parked in a disabled car park at centrelink and I got in a fight with a rent-a-cop over it. who then called the cops. So I’ gotta be could there.
The rent-a-cop paid me out about being a “brat” and how mummy and daddy bought my car, I’m all like dude your clueless. I’m at centrelink for a reason – I’m on the dole mate.
“That would be right, nothing but a dole cheat you are”
rofl that's gold.
ur a bad bad man :down:
omg, froth came out of my pee pee, is that normal?
very normal. big valves + half decently sized cams + decent amount of cam timing = lumpy as fook idle :)
that guy even had the classic noob douchebag avatar
ITS A f**kIN FLOOD HARVESTING PUMP NOT A TURBO!
awww sick pump moit
shuttup bush tucker man :)
I didnt drink you dirty little welcher. You are farkin toast next time i see you. :D
yeh josh wtf.. u shuld have been ther.. bitch head
I run quick.
i run quicker..
I think i started a war with a clown
http://www.skylinesaustralia.com/forums/t1...&start=1060
bahaha.. im so band wagon jumping now
hi :D
hiya wer wer u
YEO PEEPS!!!
hiya bish
had a good weekend finally installed my gauges & blue rice led cluster lights, jjr coil packs and some new cheap and nasty NGK's car is transformed it litterally is pulling like a farking freight train, my clutch is screwed now just from booting it as it starts to come onto boost the clutch starts to slip, water pump is also leaking real bad :)
bah leaking water pump.. my mate drove his leaking water feed line S14a for a month before he gave me money for his line and turbo.. his rad was always half full
book her into dan from elite racing mate.
i wouldnt be driving it if the water pump was leaking!
bah ull be fine.. got a water temp gauge..?? just keep an eye on it..
mine is reading 80-85 now and 85-90 with a/c on the highway.. new coolant flush ftw..
and my oil temp is sitting on 90-95 on highway now.. 0w40 might be too thin.. on the mountain it sat around 85.. but cooler up ther...
Me: excuses me, how much longer do I have to wait?
Lady: I don’t know
Me: It’s not good enough, I have been here 40 minutes, and you told me I only had too wait 15minutes.
Lady: Can you come around to the other side of the counter?
Me: How much will it cost to jump the line?
Lady: It doesn’t work like that here
Me: I don’t give a shit, how much? You told me 15 minutes; I’ve been here 40minutes. Your management sucks.
Lady: Josh, you have only been here 27minutes, do I look like a management? I can’t help that.
<centrelink room is now all attention on me>
Josh: 27minutes is not 15minutes; management needs to fix this shit.
Lady: getting angry at me wont help you in this situation, Josh.
Me: Yes it will, I have better things too do then wait f**king here.
Me: Make me an appointment at a more convenient date for me
Lady: I can do 9:30am tomorrow?
Me: Will it actually be 9:30am though?
Lady: It depends how busy everyone is.
Me: This isn’t good enough
<Walks out to the badass 911 parked out the front>
bahahaha.. she had the nerve to call u by ur first name...??? that seems a bit odd. sir and madam for customer service
I suck at myspace coding, profile is now fixed. everyone go comment
comment this.. *grabs crutch*
I spent the day f*kin around with the line spent 2hrs trying to get the front pipe off so i could punch out my cat cause its getting a tune tomorrow
i failed at getting the dump off i was at my gf's place and did not have a propper jack or anything
my spanners are too long for taking the dump off easily
marki you free tonight? wanna help me get this basted pipe off?
nope.. im cookin steakos tonight.. giddity
but come over and bring $50 and my brother will pull it apart put it together and even hug u..
why u taking the dump off.. drop the 4 14s from the cat and away u go.
ahahha yeah man, bitch called ne josh, got no Sir from the mutt
bahaha she had some nerve. i find that rude using first names when u dnt knw the person..
some asshatt welded the cat to the frontpipe/dump
so i have a split dump front pipe and cat in one!!!!
oh ok.. well if u want ill get my bro to do it.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
