not too old.. atleast its a late one.
i had same prob with the GTR bushes wearing and electrics..
with the 180sx things are cheaper and bushes are in better condition. cause its newer but i dislike the elctrics in it. have speaker drop outs and a/m gauges dropping out.
my guess its dodgy earths.
i have no problems at all with that sort of thing its all been replaced anyway
i will clear it up...the car has NO problems at all, just i personally do not like the car and feel for the money I could have done better actually a lot better, if some one else bought it they could have it the way i want for probably 2k, its just i dont care enough to screw around with it again
uve got genuine gaskets and intake gaskets... wtf..? and u dnt need a genuine gtr key
thats what happens when u bust them :D
also no gtr is complete without the real key! :sorcerer:
but u have genuine gasket kit which include intake mani gasket. and new waterpump should come with a gasket too.
and u dnt need to paint covers and bay.. and nor do u need plates. just somethings u can wait out a bit
once again mark, quality of job. also why do painting later when everything is apart and stripepd now?
it doesnt say genuine gasket kit, i bought random ones from dan. when i was dummy fitting the motor i had the intake gaskets on, and they broke when i took the plenum off.
also water pumps dont use gaskets, they use gasket goop. u shoulda known that already. its oil pumps that use gaskets.
the last waterpump i fitted used gasket and silicone.. ohhh snap.. huh..?? i basted the gasket.. on ur list it says waterpump gasket but u should knw that.. u made the list.
it says
water pump & inlet manifold gasket
which means water pump (u know the big metal thigny majingy) and an intake gasket, ya farken douchbag :D
it says which means water pump (u know the big metal thigny majingy) and an intake gasket, ya farken douchbag :D
haha
why would u group water pump and inlet gasket together. why not say
a. water pump
b. inlet manifold
ppl are gonna read it and think u want a waterpump gasket.
haha
a. water pump
b. inlet manifold
caus i bought them at the same time and i know what it meant :D
plus i only had a total price, not individual prices
no they wont.
did u get to see it before i removed the link? i can pm it to you if u want a squizz...i only removed it caus theres some prices in there im not suppose to let anyone else see/know about :D
nup didnt see it... you better PM me lol
no they wont.
ur gay
they are all the same anyway.. good ol nissan for doing that.
incorrect. rb20 and 25 differentiate wiith bolt placement
i can post the imageshack link lol... but im not that much of a dick
hmm well jspec sucked today
looking for a chaser i hope..
go see iron chef imports.. he specialises in chaser
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
