god im funneh at 3:30am!!! :P shane
anyone got a big f**k off breaker bar i can borrow on sunday/today harmonic is supposed to be a karnt to get off...
i have one as long as ur forearm and it gets my harmonic balancers off. use ur legs and ur muscles..
bahahahahaha i was gonna tell u that the other day but i assumed u already knew :(
P.S only way to get it tightened back up is to use a rattle gun
or use ur muscles.
To start with - you won't get a rattle gun in there without removing the A/C. Unless you got some super dooper short arse rattle gun that I've never seen before?
Secondly - You can use the breaker bar under the chassis rail and flick the starter to crack the balancer bolt but then you'll have the issue of doing it up again.
Thirdly - Don't do what Mark is about to suggest as I have seen mechanics pop gearboxes a few times trying to crack them with the car in gear and brakes on etc.
I have a tool which you may borrow but it must be returned. Makes everything easy and you don't have to worry about busting shit.
I assume you also have a balancer puller to get the balancer off once you have undone the bolt?
DO i wait till early december for the better deal on my car or do i take the slightly less good deal tomorrow *strokes beard*
You take the less good deal tomorra, as Dec could still fall over.
You rego the R33 so you an anna have transport.
You sell the R33 while your driving it.
When its sold; you either have your new car here or you buy/drive a beater until you get the new car.
Easy.
Dont take the Dec risk,
Edited by Nismo_Boy
lol at pics.
hey dan. i havent heard of anyone breaking a box doing it my way. infact i dnt think u could with the amount of torque u have with a small breaker bar..
i normally penetrene the night before :D life is easier that way.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
