Not as good, but all we have... I liked it here once... Maybe we can make it cool again???
Worth a shot methinks.....
Fixed
Bahahahahahahahahahahaha :D
so..... who broke sauqld?
Whores broke it. :(
Good question. My site is also down so its the hosting server that is at fault I would imagine.
I noticed this aswell when i couldn't get onto SAUQLD, so I will pm you here hopefully you get it
I now need a Bosch 044 fuel pump.
my walbro died after 5 laps of the Staduim Drift
so I missed most of the day.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
