hahaha You get used to it after a while..
Haha I used to sit in here all day at work, now I work from home time is my money lol...so I'm not wasting as much of it. Well maybe today, I'm suffering from cantbef**keditis. I do need to run to the shops though :S Gloria Jeans will make it all better.
lol What are the Symptoms? I think i may be suffering from that myself a little today too!! :thumbsup:
Symptoms are a little like the flu, just without all the pain and suffering. Also there is a strange need to procrastinate and drink coffee lots.
Hey Vish, it would suit you...the 53XYN Exa, lol yeah for $100 I couldn't go too far wrong, it even had accessories worth more than that....I thought it may come in handy this year as I'd be smashing another 50,000kms on the R34 mainly doing highway runs to the Gold Coast campus. I'd rather kill something cheap.
