her boyfriend is a lawyer, they can give me money......
LOL
i'm gonna live in their attick when they get a sweet pad!
they can feed me a bucket of fish heads once a week like Hugo!
yeh, that was yesterday dude
thought ur memory might be a bit overcroweded with work and u've forgotten all about it
lol
yes work does suck, signed the drawings off just before so im freeeeeeeee for awhile :)
got to keep workin tonight :)
major overtime this wk
didnt finish up till 9ish last night.
is that it? i didnt leave until 11 LOL
Anyway, off to fit new wheels!!!
BBL
PISCORBAN when ur finished ;)
so get off ur ass and do some work instead of postwhoring... what do you do anywayz?
dude, dual monitors FTW!!!!
work with computers, networks, etc.
totally sucks when ppl want somethin new that needs to be sourced and then implimented into somethin that wasnt designed for it from the start
lol
if ur workin back tonight, im comin to ur office to work from over there.
sittin in this buildin last night, u can hear it goin side to side with the wind
nah it looks like i'll be leavin at 5 today!
that reminds me, u get that email yesterday about our new building at 199 Grey St? apparantly its gonna be ready for us to move in in Feb 2008 :woot:
:pirate:
i mean
:fergus:
both Shane and john are working late together...
Bum Sex!!
want an invite?
that reminds me, u get that email yesterday about our new building at 199 Grey St? apparantly its gonna be ready for us to move in in Feb 2008 :pirate:
want an invite?
dont think so, whos the email from?
forward it onto me
my building is really cold :woot:
and i didn't bring a jumpie
awww poor diddums
but ull walk outside and go FCUK ME ITS HOT :pirate:
I think I might leave work in like 5 mins
hmm sounds like a plan
Guest
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
