So what box are you going to go...how much power are you intending to make? The os giken and ppg gearsets have been used in some pretty high hp cars that do regular track days. You aren't going to go with something dog engagement are you, talk about spending your weekends stripping down your box to check everything out after a day at the track....no thanks.
800bhp is what i've speced everything else to, but prolly be lucky to make 750bhp. i know theres some pretty decent hp cars usin the os kits, but then theres just as many people who have broken os kits. Also from what i've seen you only strip down a dog box after a year of racing, just to check it then.
I dont know, from what I researched when I was looking at boxes, dog boxes are very high maintenece, especially if driven on the street as they don't select gears well. Also unless you opt for billet selectors they have an even shorter life span. I am pretty sure SydneyKid was saying they strip their boxs after almost every race meet as it's necessary to check for problem components...and iirc he was talking about how they had to replace items rather regulary as they started to wear down. I think they are perfect for track only cars, but a bit of a problem for street driven cars.
periodic maintenance far outweighs the need for a complete replacement if u do smash an os set, @~5k for a ready to go os 5speed
plus theres the likelyhood of this gtr becoming a track only car, i can see it happening
From a back yard car to a track only car. Thats quite a contrast :domokun:
From a back yard car to a track only car. Thats quite a contrast :P
you like? :domokun:
P.S eat a dick fanboy
http://www.skylinesaustralia.com/forums/in...c=159419&hl
there's a more recent article on the ppg dog boxes....
yeah i read that, and i aint goin ppg lol, i've seen 1 ppg break, and whitnessed issues with another on the weekend (the later bein a 2 weekend old box, the other a 2 yr old box)
all I can say is I can't wait to see and go for a ride in your car once its finished Shane!!
i'll be the first to say it...youll be waitin a while lol. the engine's nearing finish time and startup, but theres the suspension side and braking side i gotta take care of before i go spastic with driving it in anger
all good things take time....or lots of money.
you know you can drive when you can drive with a dog box too....good bragging rights :P
that and coupled with a super light twin setup :P
Im looking foward to racing it :)
it'll be interesting to see indeed!
i would say u'd have me from down low, but seeing a result with a built 26/30 coupled with a TO4z from UK, 1bar by 3200rpm on the run in tune, i reckon i'll be on song very early! :domokun:
Guest
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
