Strut brace, nice! Needs a pod filter too huh? No biggy
Pod filters arent actually that good, this one has a upgraded panel in the stock airbox...similar flow with less heatsoak.....pod filters are also another favorite on the coppers list! This car was made to not draw attenetion, and it works! Buuuuut that said if/when you own it go nuts!
For people in parts of the
Southeast Coast Forecast District.
Issued at 12:23 PM Wednesday, 15 November 2006.
At 12:15 PM , Bureau of Meteorology weather radar detected severe thunderstorms near Lowood and the area southwest of Esk. These thunderstorms are moving towards the east to southeast. Severe thunderstorms are forecast to affect Esk and Ipswich by 12:45 PM and Bundamba Lagoon and Greenbank by 1:15 PM .
Large hailstones and damaging winds are possible.
A more general severe thunderstorm warning is also current for the Southeast Coast and parts of the Central Highlands & Coalfields, Wide Bay & Burnett and Darling Downs & Granite Belt Forecast Districts.
The Emergency Management Queensland advises that people should:
* Move your car under cover or away from trees.
* Secure loose outdoor items.
* Seek shelter, preferably indoors and never under trees.
* Avoid using the telephone during a thunderstorm.
* Beware of fallen trees and powerlines.
* For emergency assistance contact the SES in your local government area, listed in the White Pages under either State Emergency Service or your local council.
The next warning is due to be issued by 1:25 PM.
This warning is also available through TV and Radio broadcasts, the Bureau's website at www.bom.gov.au or call 1300 659 219. The Bureau and Emergency Management Queensland would appreciate this warning being broadcast regularly.
Nah dont want to go to nuts, for similar reasons, dont need the hassles. We will see will probably put a plumb back on it not a huge fan of loud BOV's
It has the stock one still, plumbed back :) Unless you are making silly power with masses of boost the stocker is fine
When you replaced you motor in the 32 you put a 25 in didnt you? What does it make now that you had it tuned?
It always had a 25, now it has a better 25. Still 245 at 16psi I couldnt turn the boost up anymore as a dodgy gasket was causing surging
stupid workshop *shakes fist*
*screams* YES I AM PAYING THEM OUT BECAUSE THEY f**kED OUR CAR!!!
Who what when where and why?
*settle down, there Anna you dont want to throw a leg out of bed for over revving*
Hope the 33 is under cover shane!
hell no! its out in the yard with a big "STRIKE HERE" sign :)
nah i jsut rang home to see if its bad or not, apparantly there was only a few wee hails, but its over now, and both cars are under cover :)
Guest
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
