ok so i finally finished installing my FMIC today and went for a lil test drive in it. Had the boost controller adjusted wayyy out so stock boost. Gave it a bit and i felt it jump back alot once i hit 4.5k rpm. It used to do this before i adjusted the boost up to 12 so i just assumed it was that and got out and adjusted it up (although it had done it more than before) so i cranked it to where 12 psi is, then accelerated in 1st to about 4500 rpm. Felt a bit better until i hit the 4500 rpm then a loud bang and a whizzing sound from my turbo. Then the car stalled. .. I started it once more and it idles but very roughly and the turbo whizzes very loudly, as soon as i put any strain on it it stalls, I can hear a rattling sound coming from my inlet manifold to. Is my turbo/engine rooted? If so what would have caused it? Could it be a problem caused by some kind of intercooler leak?
Edit... hose ^^
Edited by r32 gts-turbo
wait up, was a hose came off but was ver hard to see from the angle i was looking at lol. Um should my inlet manifold be rattling tho, the hose is on but im scared to start it as im scared it sucked up some crap into the manifold and its siting there
yeh was the hose, sorry if my sentences sucked, i tried to say nevermind it was a hose but came out all retarded. I think was just something to do with unburnt fuel or something causing the ticking in the inlet manifold. With hoses on its gone. Was woried :)
have got a problem still tho. I get what sounds like an annoying constant beeping as soon as boost kicks in. Its not the normal turbo spooling sound and doesnt incease in frequency much.. Is this because of the new cooler or something? Or is there likely to be a boost leak somewhere
found the problem, the underside of one of the silicon joints had a split in it :) Thought those things were good for a fair bit of pressure and stretching (didnt overtighten em) ive replaced it and will eventually replace them all. Its the justjap kit, all the welding is pretty mickey
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
