What sorta power should i be getting @ the wheels out of my RB20DET ECCS with the following mods :
* 3 inch dump pipe into a 3 inch hi-flow cat, 3.5 inch zorst from the cat back
* 10 psi of boost
* k & n pod type air filter
I got it dynoed and wasnt too impressed with the outcome, not that i was expecting big horsepower but this wasnt much of an improvement from the standard power output. I got 160hp @ the wheels.
You guys reckon this is a pretty accurate reading or is the something wrong with the car?
cheers
sLo :P
https://www.sau.com.au/forums/topic/11982-what-sorta-power-should-i-be-getting/
  • Replies 42
power? you should use 240V AC if your in Australia.
Seriously, don't worry about comparing dyno figures except with your own from the same day and dyno.
Is 160rwhp too low? Probably not. Why don't you see how fast you car is. If it's too slow for you modify it some more.
If beating other people in a dyno comparison is what you like to do then knock yourself out.
I had exactly the same mods and made 109kw at the wheels with 10psi.
I will not put my car on the dyno again unless I have added a substantial mod and want to see what I have gained or am getting something tuned at the time.
Trying to keep a handle on maintanence negates me modding extensively at present.
I feel slow sometimes and when that happens I go drive my g/f's mirage or someother sh*tbox and then get back in my car again. Trust me you will feel the difference!
edit-sorry, tell a lie I only had a catback on the dyno.
slo-32 - I got 114rwkw when i had mine done last Thursday. Had the same problem as you with timing i saw in an earlier post of yours, except my timing had been set wrong. Started at 70kw and i thought what the! after that they realised the timing had been set wrong and ended up getting 114 :( very happy with it.
Mods i have are pod and turbo back exhaust and running 14psi i think on the Apexi AVC-R i had installed on the same day. Nor unless they did the power run at 12psi, but dont think so. Cant wait to see what it'll do with a few more mods i wanna do like cooler and bigger turbo :D
BTW - what is conversion of hp to rwkw?
Mine was 143rwkw with Trust element in the stock airbox, HKS Super Drager cat back exhaust and Supra front mount cooler, stock boost.
With a pod filter, front pipe, custom FMIC it made 153rwkw at stock boost
Chris
itsallgood : 160rwhp = 119rwkw i think...well around that
Chris32 :
... 153 rwkw?! You sure you dont mean hp? Surely a FMIC doesnt give you that much power does it? Correct me if i'm wrong.
Cheers
sLo :P
Guest INASNT
Chris32 :  ... 153 rwkw?! You sure you dont mean hp? Surely a FMIC doesnt give you that much power does it? Correct me if i'm wrong.
Cheers
sLo :P
yes u r very wrong, fmic gives u about 30rwkw gain at same boost level over stock cooler.
Stock cooler is the biggest restriction in the whole system.
I remember alot of ppl saying a fmic doesn't really do shit with a 32? Either way i should have mine back (fkn taxi ran me off the road) in around another month. She comes back with a micks metalcraft 600x300x76 so ill be able to comment :P
With stockbox, 3" exhaust str8 thru, 10 psi, and timing on around 30 (no pingage pphhoaarrwww) we were on around 138rwkw.
What have other ppl noticed that have swapped to a fmic in a 32?
I've run 35degrees base timing on regular bp98. About 25-30degress at the moment.
fmic will always make a difference. The peak power will be higher for sure. The only problem is some 'oversized' fmic packages will lose response over the factory and make the car slower to accellerate over 400m.
Originally posted by INASNT
people who say fmic dont make a difference obiliously dont have one or have even had one!
I agree with you totally, though from everything ive read, suggests that without say a new turbo etc, changing the IC on a 32 doesn't make a great deal of difference.
Now ive seen 100 of ure posts saying "omg my fmic gave me 30wrkw" :D, im just wondering what i should be expecting...5? 10? 30?
Yes INASNT...I have never had a FMIC. In fact this is my first turbo car and still learning alot about them. And I am learning a great deal from you guys at this forum.
The only reason i questioned the power gain from a FMIC is becuase i've been in a s14 with a cooler and one without and the one without went alot harder / better. And they pretty much had the same mods. But i now know there is many factors that could have made this be.
Thanks again
sLo :D
I never dyno'd it with the stock cooler, but I reckon it was around 120rwkw. As I said before, with the 7MGTE Supra cooler it made 143rwkw, and with a proper custom job it made 153rwkw. All with no change to the stock boost.
Currently its making 198rwkw with a HKSGT2510 and a re-mapped computer and decent intercooler.
I'd recommend a bigger intercooler to any one with a stock cooler, the amount of extra grunt thats lost through the stock cooler is a joke, and retaining it is also a joke - bigger is better!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
