Your lack of intelligence does not surprise me! Nor does the fact that your immediate response to someone voicing an opinion (good,bad or indifferent) that doesn't align with yours, must mean that they're intellectually challenged with a predisposition to suicide!
I was just stirring because it looks just like every other 300ZX on the road, a rushed under cooked wedge looking thing suppose to hold a candle to the other sports cars of its era!
I was stirring shit! So consider yourself "a piece of shit" and consider yourself "stirred"! :laughing-smiley-014:
Stirring shite is for the wasteland. This is a legit post and there's no need to crap in it like that.
Blitz.....what happened to yours that made it such a mistake?
haha Get Angry son! :)
Dont get me started.
The list of problems was long but distinguished.
whoa there people, calm down, no need to start another fight here. Whether or not you like it or not it's totally up to you guys, no need to start a fight with each other.......and on that note.............I STILL LOVE 300ZX!!!! that is all
I owned a series 2 R33, swapped it for a 300zx with a few mods. I have regretted it every day since. The car costs heaps every time something minor goes wrong (which is monthly) the engine bay is so cramped that i tore 75% of my hands off changing radiator hoses and no matter how much car i take with it something new goes wrong.
I suggest to those who are considering a zed, mkae sure you have PLENTY of patience!!!
But to stay on topic with this thread that white zed did look quite tidy.
They arnt exactly the easiest cars to work on.
Simple things such as a spark plug change require the engine to be pulled.
LOL,
U probly heard it of some 1 huh?
they spark plugs was on top!
no need to pull engine...LOL
I had 1, I could called myself lucky, never have any major problems since 2 yrs of ownership!
the 300zx cockpit feel like a true sport car, if u ever sit in 1.
skyline, i feel its like a family car.
and the torque, omg, the torque!
hard to find a good clean 300zx, but if u found 1, U gona love it to dead!
I sat in my friend's 300z a while back, was bloody awesome.
Back then I didn't know much about cars, and he had a full veilside kit with a massive exhaust. I thought it was a super car of some sort.
Nice car.
They aren't that bad to work on geeezuz. I have one and enjoy working on it you pansies :P
I'll go with Lysergic on this one! Alot of what you guys hear about the 300ZX is BULL$%T urban myth. Any import (Zed or otherwise) that hasnt been taken care of, rolled off the boat and driven will give troubles and overheat.
Yes I am biased as I own one, but its been the best car I have ever owned. I race the thing (club, hillclimb, supersprints etc) and drive it hard regularly and it gives few drama's (only minor ones you expect from a hard driven car).
They can be awkward to work on but most of the normal maintenance shit is as easy as a Skyline. Turbo changes are a bitch but hey thats what you pay for an awesome handling and low slung package. They can be made to handle extremely well with little money and are a dream to drive.
Dream garage one day will be Z32 and R32, what great packages.
MattB
Edited by wokburner
