Extremely well maintained R-34, garaged daily, servied every 5000kms( Motul 8100 Engine Oil) Female owner, No accident . Major Serviced in 95800Kms, Includes: *BRAND NEW EBC Brake Discs and Pads* +*BRAND NEW Exedy Heavy Duty Racing Clutch*, Modification includes:
*HKS Hi-Power Exhaust system
*HKS Front Pipe
*HKS SSQ BOV
*HKS SPF Intake
*BILSTEIN Adjustable Suspension
*Exedy Heavy Duty Racing Clutch (NEW!)
*EBC Brake Pads (NEW! changed on 95800kms)
*EBC Brake Discs(NEW! changed on 95800kms)
*Blitz Turbo Timer
*18'' HR Racing Rims
*Falken ZX 245/40/18 (Brand NEW!)
*Other:
JVC KD-SH99R MP3 Player,
Coustic Speakers,
KIKER Sub Woofer.
Tinted Windows.
Viper Alarm System.
Standard Parts includes:(they will go with the car)
*Standard Front Pipe
*Standard Clutch
*Extra standard automatic mirror
Never boosted up over the factory setting! it has done 98000kms. (NEW Clutch & NEW Brakes& Resent Major servied). The car is in a very good condition now. 1 year registration. The reason for sale is due to new car comes in. $29980 ono. Genuine buyers only pls! (0433214604/[email protected])
Edited by haorui34
https://www.sau.com.au/forums/topic/119910-98-skyline-r34-gtt/
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
