Hi guys
Ever since I bought my r32 rb20det I get this weird problem when driving and only recently I found the symptoms of it
Sometimes when I start it (cold start) I have to tap the throttle to get the revs up then it idles perfectly with no problems and warming up is fine
When im driving at like 60kmh in fifth gear I put the clutch in and the revs go all the way to 0rpm and battery light comes on etc, but if I tap the throttle it the revs would go up accordingly and then get back off the clutch it will come back to life as in the revs would be back to normal
Is this something to worry about?
Sometimes also at low speeds, if I'm on the clutch and I apply the brake really hard to stop at intersections it does the same thing and the revs die to 0rpm and all lights come on, but then tap the throttle or clutch out and it kicks back itself again...
Could it be some sort of leak somewhere?
Any advice would be appreciated
https://www.sau.com.au/forums/topic/120014-weird-rpm-problem-at-certain-speeds/
then it could be an inlet leak from a split vacuum hose or injector seals, you can test for this with a can of degreaser/rp7/WD40/carbi cleaner - if there is a leak, then the spray gets sucked in and the engine revs will rise as it burns that fuel..
give it a try on vacuum hoses, injectors, between the upper and lower sections of the plenum etc etc
thanks guys will give it a go
yeah i sprayed before just near my plenum i had a leak there on inlet manifold
i have changed my inlet manifold gasket because inside cylinder 5 and 6 air was choking a bit there and its all fixed now so no more severe idle problems, like the car is driveable now but just if you jump hard on brake or clutch in the revs will go down severely but then kick up again
yeah start up issues on cold
when i start it on cold without tapping the throttle it is hard to start
i have had my alternater reconditioned so it's like brand new
on my apexi pen timer it shows 12.2 - 12.5 volts on the battery but the reading also flashes indicating it is also at low voltage
i'm planning to buy a new battery soon but there is no problem with it being charged
i have this same problem its really pissin me off gota get to the bottom of it now
stalls coming up to lights on clutch in/brake and have to heel toe blip accel to keep it alive, starts 1 in 5 cranks too :laugh:
ive sorted the battery, coil packs, plugs and wired fuel pump to 100% duty (040 just making sure lower setting wasnt causing stall) and no love
next i guess ill check afm, aac, injectors :
yeah my problem seems identical to yours inissane although my car is driveable only when i get on the brake hard with clutch in it stalls but then comes back
also hard to start aswell like you said
i might try battery
ive changed afm aswell
and ive cleaned aac valve ;p
i wired my fuel pump aswell to the boot so it bypasses the ecu (could be the problem?) i might change that back this weekend
will post results
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
