In the next few months will start to bolt up the GT35R to my R33 gtst. at the moment i have it with a 0.83 exhaust housing. Will be bolting this up on the standard motor so not expecting it to last long.l What i intend to do is rebuild the motor again but with forgies and the lot.
One thing i have considered is stroking the motor. I have heard of the tomei 2.8L kit for $7500 with with crank/rods/pistons. Rather than forking out this much can i use a GTR crank? will this stroke out the motor? How much? has anyone done this? what exactly is involved.
im not too cluey with all this stuff so any help is appreciated. what costs are invlved with a reliable 400rwkw rebuild?
Thanks..
https://www.sau.com.au/forums/topic/120375-full-engine-rebuild/
the point of the rb30det is more displacement,. you wont need to rev past 7 grand. it will make its peak power near 4 grand instead of 6 (rb25 style).
so theres no need to rev it so high. you are much better off revving lower (less loss and friction) than revving to 9 grand (rb20 style)
you'll never get 2.8l consider than the larger rb26 black uses a GTR crank and its only 2.6 litres. you get about 2.55 or something.
i was considering a similar operation for my rb20 but the machine cost for the block are huge - it would be slightly less for an RB25 but still very costly.
you could put forged pistons and rods in the 25 and with that turbo and a really good ecu you should make 400 rwkw but seriously if your gonna go that far just get a new block 26 or 30 and slap your 25 head. if you use a GTR block crank rods and forged pistons and a good ecu you be able to safely support 400rwhp... for a while. there's plenty of ppl on here selling their GTR bottom ends.
talk to a workshop or machine shop for quotes because you HAVE to get the stuff machined, if you don't you blow gaskets like a prostitute.
RB30's are probably the best option.. although i'd like to see someone put a barra 204t in a skyline... see my signature.
agree with not revving hard. i have to rev my 20 to 8G in 2nd to get the best pull into 3rd gear.
putting in a larger crank means machining the block so that it will turn and not hit the sides with the larger rod bolts it requires
also i think you'll need new rods because the stroke with the new crank will be wrong (longer or shorter i'm not sure) and you will need new pistons to hold up 400kw.
on top of that when you build a new engine you always getknew rod bolts, head styds etc and like i said before you get it machined. muchos deneros needed
Rb30DET is not the answer.
The 25 has a greater flowing head than all the others so it is by far the best choice for modification. You can go to an RB30 bottom end and retain the 25 head which has proven itself many times before. There are some problems in block design that need to be remedied before you could consider it a reliable option.
You will need around 2 grand to spend on porting and you will also need a decent cam like a HKS step 2 or step 3 if you want the funky idle.
Retain the standard crank and rods but have them shot peaned and nitrided or cryo treated. There is absolutely no need to go to 2.7 or 2.8 litres to achieve a small figure like 400rwkw. The GT35R you have will max out at approx 450rwkw anyway so you'll probably need to be running in excess of 24psi to get your 400. This means dish pistons. Don't muck around with gay metal head gaskets coz they are a waste of time and are not as durable as the standard factory head gasket.
You will also need a full ARP stud kit for the entire engine.
Make sure you tackle issues like oil control in the head with your engineer as this is a major issue in the RB's. Not only getting the oil in there but getting it out again.
If you want the engine to be reliable at that hp figure you should consider AT LEAST an N1 oil pump but I would highly recommend a JUN item which will definately outlast the N1. You are going to need to upgrade your throttle body at least and should use an aftermarket plennum while your doing it. All of the inlet piping will need to be 3 inch and the intercooler should be an efficient bar and plate design or something at least 600 x 350 x 100. PWR make some very nice coolers that will do the job nicely.
Don't forget about driveline either as the standard g/box will need to be upgraded to dog engagement and you will also need a decent twin plate like the one I sold R33skyliner. It is the same one used in Mark Jacobson's 9 sec GTR.
Don't worry about the driveshaft too much and definately don't go to a one piece tailshaft if you want to be able to rev the engine past 7 grand. One piece 3 inch tailshafts go critical at around 6500 so big bangs can happen after this point. It is better to retain the original unit but upgrade the centre bearing and unis.
I have an Rb30det, if a drysump system is used, the engine is quite capable of revving up to 9000rpm. P.S. The engine is up for sale if your interested (rb26/30)
Why do you need a drysump to rev to 9k. My Rb20DET revs to 9k several times a day with no hassles.
what on earth?
stock rb25 head
stock rb30 bottom
poor mans rb30et pistons
suitable injectors
suitable ecu
suitable exhaust
stock gaskets
suitable manifold, gate, turbo
should make 300rwkw relibably and easily.
you are reading too deep into it 3litre32
sky30:
My Rb30DET in a R32 skyline
Stock RB30 bottom end from a VL commodore (300,000+kms)
Stock RB25 n/a head, Stock cams with heavier valvesprings
Stock exhaust manifold with GT35/40
Stock plenum/inlet manifold
3 inch exhaust
FMIC
550 cc injectors and bosch 044 pump
Microtech ECU
Made 306rwkw on 20 psi with 550nm torque, have since added 260deg cams and made 312rwkw with better midrange power & torque.
Power peaks at 5800rpm, then drops of pretty quick, i suspect this is caused by the stock exhaust manifold which i will change soon.
Guilt-Toy
R33 GTST
RB25det head with VVT oil line
Standard Bottom end rebuilt with new rings and bearings only
Nismo 740cc Injectors
Sard Pressure Reg
Walbro 550 pump
Plazmaman Plenum
300x600x100 Intercooler
Extractors
GT3540 .82 rear Turbo
Tial 38mm Gate plumed back
Power FC & HC
3" exhaust
Made 346.6 RWHP on a conservative tune (low timing) on 16psi. Will post pics and dyno sheet. Got it tuned on Saturday and the dif blew on sunday lol. Bit worried about the bottom end so I did not go above the boost level sydney kid recomended.
conan-7772:
RB25/30
Stock plenum
Stock cams
Stock injectors
Stock head, serviced, ported & polished
Rising rate fuel regulator
Rev I-beam Conrods
CP Pistons 8.3:1
CP Rings
N1 oil pump
Powermax water pump
ARP main studs
ACL Race Series Main and Rod bearings
ACL Valve Stem seals
3 inch exhaust
Haltech E6K management
Haltech ignition
Haltech boost controller
No AFM, map sensored
Front mount intercooler
911T Fuel pump + surge tank
High flowed turbo , Hitachi internals, looks like stock housings to me but compressor housing possibly different.
Compressor housing bored to take a 56 mm wheel(inducer) , 500 hp bb core , Exhaust housing bored to take a larger steel wheel, size unknown. Pics of turbo posted in discussion thread.
Apexi BOV
Injectors at 96% duty, fuel pressure on full throttle 68psi
293.7 kw and 462.7 Nm
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
