In the next few months will start to bolt up the GT35R to my R33 gtst. at the moment i have it with a 0.83 exhaust housing. Will be bolting this up on the standard motor so not expecting it to last long.l What i intend to do is rebuild the motor again but with forgies and the lot.
One thing i have considered is stroking the motor. I have heard of the tomei 2.8L kit for $7500 with with crank/rods/pistons. Rather than forking out this much can i use a GTR crank? will this stroke out the motor? How much? has anyone done this? what exactly is involved.
im not too cluey with all this stuff so any help is appreciated. what costs are invlved with a reliable 400rwkw rebuild?
Thanks..
https://www.sau.com.au/forums/topic/120375-full-engine-rebuild/
the point of the rb30det is more displacement,. you wont need to rev past 7 grand. it will make its peak power near 4 grand instead of 6 (rb25 style).
so theres no need to rev it so high. you are much better off revving lower (less loss and friction) than revving to 9 grand (rb20 style)
you'll never get 2.8l consider than the larger rb26 black uses a GTR crank and its only 2.6 litres. you get about 2.55 or something.
i was considering a similar operation for my rb20 but the machine cost for the block are huge - it would be slightly less for an RB25 but still very costly.
you could put forged pistons and rods in the 25 and with that turbo and a really good ecu you should make 400 rwkw but seriously if your gonna go that far just get a new block 26 or 30 and slap your 25 head. if you use a GTR block crank rods and forged pistons and a good ecu you be able to safely support 400rwhp... for a while. there's plenty of ppl on here selling their GTR bottom ends.
talk to a workshop or machine shop for quotes because you HAVE to get the stuff machined, if you don't you blow gaskets like a prostitute.
RB30's are probably the best option.. although i'd like to see someone put a barra 204t in a skyline... see my signature.
agree with not revving hard. i have to rev my 20 to 8G in 2nd to get the best pull into 3rd gear.
putting in a larger crank means machining the block so that it will turn and not hit the sides with the larger rod bolts it requires
also i think you'll need new rods because the stroke with the new crank will be wrong (longer or shorter i'm not sure) and you will need new pistons to hold up 400kw.
on top of that when you build a new engine you always getknew rod bolts, head styds etc and like i said before you get it machined. muchos deneros needed
Rb30DET is not the answer.
The 25 has a greater flowing head than all the others so it is by far the best choice for modification. You can go to an RB30 bottom end and retain the 25 head which has proven itself many times before. There are some problems in block design that need to be remedied before you could consider it a reliable option.
You will need around 2 grand to spend on porting and you will also need a decent cam like a HKS step 2 or step 3 if you want the funky idle.
Retain the standard crank and rods but have them shot peaned and nitrided or cryo treated. There is absolutely no need to go to 2.7 or 2.8 litres to achieve a small figure like 400rwkw. The GT35R you have will max out at approx 450rwkw anyway so you'll probably need to be running in excess of 24psi to get your 400. This means dish pistons. Don't muck around with gay metal head gaskets coz they are a waste of time and are not as durable as the standard factory head gasket.
You will also need a full ARP stud kit for the entire engine.
Make sure you tackle issues like oil control in the head with your engineer as this is a major issue in the RB's. Not only getting the oil in there but getting it out again.
If you want the engine to be reliable at that hp figure you should consider AT LEAST an N1 oil pump but I would highly recommend a JUN item which will definately outlast the N1. You are going to need to upgrade your throttle body at least and should use an aftermarket plennum while your doing it. All of the inlet piping will need to be 3 inch and the intercooler should be an efficient bar and plate design or something at least 600 x 350 x 100. PWR make some very nice coolers that will do the job nicely.
Don't forget about driveline either as the standard g/box will need to be upgraded to dog engagement and you will also need a decent twin plate like the one I sold R33skyliner. It is the same one used in Mark Jacobson's 9 sec GTR.
Don't worry about the driveshaft too much and definately don't go to a one piece tailshaft if you want to be able to rev the engine past 7 grand. One piece 3 inch tailshafts go critical at around 6500 so big bangs can happen after this point. It is better to retain the original unit but upgrade the centre bearing and unis.
I have an Rb30det, if a drysump system is used, the engine is quite capable of revving up to 9000rpm. P.S. The engine is up for sale if your interested (rb26/30)
Why do you need a drysump to rev to 9k. My Rb20DET revs to 9k several times a day with no hassles.
what on earth?
stock rb25 head
stock rb30 bottom
poor mans rb30et pistons
suitable injectors
suitable ecu
suitable exhaust
stock gaskets
suitable manifold, gate, turbo
should make 300rwkw relibably and easily.
you are reading too deep into it 3litre32
sky30:
My Rb30DET in a R32 skyline
Stock RB30 bottom end from a VL commodore (300,000+kms)
Stock RB25 n/a head, Stock cams with heavier valvesprings
Stock exhaust manifold with GT35/40
Stock plenum/inlet manifold
3 inch exhaust
FMIC
550 cc injectors and bosch 044 pump
Microtech ECU
Made 306rwkw on 20 psi with 550nm torque, have since added 260deg cams and made 312rwkw with better midrange power & torque.
Power peaks at 5800rpm, then drops of pretty quick, i suspect this is caused by the stock exhaust manifold which i will change soon.
Guilt-Toy
R33 GTST
RB25det head with VVT oil line
Standard Bottom end rebuilt with new rings and bearings only
Nismo 740cc Injectors
Sard Pressure Reg
Walbro 550 pump
Plazmaman Plenum
300x600x100 Intercooler
Extractors
GT3540 .82 rear Turbo
Tial 38mm Gate plumed back
Power FC & HC
3" exhaust
Made 346.6 RWHP on a conservative tune (low timing) on 16psi. Will post pics and dyno sheet. Got it tuned on Saturday and the dif blew on sunday lol. Bit worried about the bottom end so I did not go above the boost level sydney kid recomended.
conan-7772:
RB25/30
Stock plenum
Stock cams
Stock injectors
Stock head, serviced, ported & polished
Rising rate fuel regulator
Rev I-beam Conrods
CP Pistons 8.3:1
CP Rings
N1 oil pump
Powermax water pump
ARP main studs
ACL Race Series Main and Rod bearings
ACL Valve Stem seals
3 inch exhaust
Haltech E6K management
Haltech ignition
Haltech boost controller
No AFM, map sensored
Front mount intercooler
911T Fuel pump + surge tank
High flowed turbo , Hitachi internals, looks like stock housings to me but compressor housing possibly different.
Compressor housing bored to take a 56 mm wheel(inducer) , 500 hp bb core , Exhaust housing bored to take a larger steel wheel, size unknown. Pics of turbo posted in discussion thread.
Apexi BOV
Injectors at 96% duty, fuel pressure on full throttle 68psi
293.7 kw and 462.7 Nm
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
