Illegal as far as I know....they made special mention on these wings on current affair hoon special a while ago...saying that it may chop someones head off in the event of an accident :)
BTW, I spotted you today I think as I was heading to moss st in the afternoon...drove right past you..couldn't miss those black work meisters!
Oh man yeah i saw that section on the news abt hoons and the police cracking down on them...defects galore manz....sheesh actually i don't intend to use my gt wing on the streets, i just want to put it on at home and drive with it to the track and then from the track back home that's all...its kindda impossible fer me to transport it there n fit it on there itself... :mellow:
Yeah i was around the slacks creek area this afternoon, actually i was getting a bit lost...so didnt really notice ya driving past me... :mellow: i was trying to find the 101 workshop to ask if they could fabricate my battery bracket fer me...kindda in a rush to get my dry cell battery in fer track day next week...
The rules state there are no sharp parts to be protruding from the vehicle and popo may view canards and or wing as a sharp item. I am unsure if its something you may be able to get an engineers cert for however the chances of being done while driving to the track are quite slim. Has happened but you'd have to get a real pig of a cop to give you a ticket if you explained to him that your on your way to the track. Just think about how many ricers you see driving around every day though with big aluminium gt wings hanging out the sides of there lancers though.
lifted from the qld transport website:
Side skirts, front and rear spoilers may be fitted provided road clearance and air flow for brake cooling is not adversely affected. They must not be fitted so that it is likely to increase the risk of bodily injury to any person. All material is to be of a suitable thickness and be free from sharp edges or corners.
Rear spoilers must be within the body shape/outline of the mounting surface (for example boot outline). Minimum thickness of end plates is 4mm and they must be free of sharp edges or corners.
for a list of modification rules, including wheel size, steering wheels size, bonnet scoops etc go to http://www.transport.qld.gov.au/qt/LTASinf...ion_Jan05v2.pdf
well think about it, if you hit somebody they smashed your windscreen rolled over your car and off the back the first thing i would be thinking is sh*t i hope the wing doesnt hurt them
thats not the issue
The issue is if you have a monster length wing that sticks out further than the width of your car, there is a genuine risk that you can cause some serious damage to someone if you come past them a little too close at speed.
There are some wings out there that are that big, and its not too much of a stretch to imagine them causing damage.
some wings are ok, but they generally use the same ruling as a bullbar, no sharp edges pretruding from the vehicle. same with intercoller edges, if u have a cut out front bar and leave the intercooler egde uncovered by the front bar, see ya! i got fined for this in a mates 200.
Edited by 85URK
Well looking from the rear, the width flushes with the fenders, or slightly smaller perhaps..end plates are rounded with no sharp edges....but its definitely wider than the width of the rear boot...
I guess carnards on the front bar are definitely a no-go...
i think the last thing going through anyones mind when getting run over is holy shit he's got a performance spoiler i'm going to die...and i am under the impression that nearly all wings would break or break off after being hit odd 70kg ( example) of dead weight...
9kpm: well i'm happy enough to travel daily without a wing at all..just wanna be able to get to the track in peace with the GT wing on...well i managed to drive to QR this morning with my GT wing on and got there and back safely....there was a traffic bike cop filling up at milton BP with me this morning..i was thinking oh shit...but he didnt even walk over..he saw me but just went to his bike after paying n headed off...phewwww...lol
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
