hey aidan, just to let you know, i just got one about a week ago and paid $25 inc ex post! (i think i was lucky)
try posting in the wanted section if you have not already
yeh posted in every state section and in the wtb
maybe i could borrow yours for the drift day then give it back if i dont get one haha!
that would be tip top! found one on ebay but doesnt end for 2 more days, will wait and see... I might need to get someone who is pretty clued up on turbos to have a quick look at it first cause when spinning it by the exhaust wheel it makes a clipping noise, not when spun by intake... and no noise if you push the exhaust inwards as you spin it, was told it was working fine on car not missing a beat just when removed they discovered this noise.... so hopefully should work fine as is.... or just rip the ex wheel to bits lol
Edited by da_snuff
Hey ppl.
soz dont have a r33 elbow would also love one myself though. I have 2 bloody r32 elbows and need a r33 one
so if there is a 2nd one out there then yeh would b apreciated aswell..
cheers nick
hey nick, think i might have found one for ya! and one for myself ;)
will pm you where to find it :P
oh yeh and i always see ure car outside my dads place, near woolworths, and its lookin good these days :)
Edited by da_snuff
i think thats the one we need by the sounds of it. its the one that goes from the turbo to the intercooler and i better let da_snuff have that one as i asked 2nd
cheers arsnik
the one i have is the standard cast elbow thats bolts to the back of the turbo (exhaust side) is this what he needs?
cheers toff, was at josh's just before and the car is gettin there, will be tuffffffffff :P
we're gonna hav to put ure name down the side of the car for all the parts uve donated :)
cheers mate
arsnik, if you have any trouble getting one now, ive got heaps of names of people willing to get rid of em haha
aidan
ive definately got one and im giving it to jp if you still need it :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
