Mod's there has been an increase unrelated threads been started in the "Cefiros and other RB powered sedans" section. Many of which should of been in general maintence or forced induction/ NA areas etc.
Only way many of the regulars in the ceffy and 4 door section think we can stop this is either getting some more active mods in the section or possible changing the name of the section to "Cefiros and other 4 door related discussion" or "Cefiros and Jap Taxi talk" etc. seems too many are getting confused with the RB powered sedans part of the title (and when viewed on the forum index its towards the top of the page, hence probally the spontanous posting of alot of newbies in the section)
example are (just ones that i quickly noted on the first page....):
http://www.skylinesaustralia.com/forums/in...howtopic=121049
http://www.skylinesaustralia.com/forums/in...howtopic=120676 (has some comments on the issue in it...regarding section name change)
http://www.skylinesaustralia.com/forums/in...howtopic=120185
http://www.skylinesaustralia.com/forums/in...howtopic=120054 (Which was eventually moved and edited by a mod)
http://www.skylinesaustralia.com/forums/in...howtopic=119291
http://www.skylinesaustralia.com/forums/in...howtopic=111613
http://www.skylinesaustralia.com/forums/in...howtopic=115186
http://www.skylinesaustralia.com/forums/in...howtopic=117973 (Thread discussing the problems we have been having)
Can one of the web admins possibly help us in changing the title of the section, helping us with some more active mods or some other option?
Cheers
Ben
Edited by skypy12
yikes... i'm the one who's supposed to be responsible for the cef section... I'll have a look at it guys... just haven't been active in that section for a while. Should be... I've been drivin the cef more than my R32 recently :D
actually... since both narkeh and someonestolecc both stepped down from moderating the section, there's only me to look after it.
Can I have some volunteers for 2 new mods to look after the section? (Obviously you have to be a reg in the Jap Taxi section to apply). Also I'll probably change the section name to "Cefiros Australia" and point the domain name www.cefirosaustralia.com to it soon.
sounds good funkymonkey. Though changing name to section name to "Cefiro's Australia" might be disregarding other 4 doors don't u think, or will it be assumed that they post in the same section?
sweet never knew cefirosaustralia.com was a registered domain, will have to get some stickers made up for that. :)
well when I made the section I assumed Cefiros and other RB Powered Sedan's might be clear enough to stop non 4 door owners from posting there.
just guesstimating... 80% of the guys in there own ceffies and 15% own 4 door R32's. the rest are a scattering of Laurels and Cimas. (No Gloria or cedric owners yet methinks).
Maybe renaming it to "Cefiro's and other Taxi's" as suggested or something like that might help.
dangerous_daveo has been made the new mod for this section. Also the section and its description have been altered.
Each section can have up to 3 moderators, so I will add another mod in due time.
The Cefiros and other RB powered sedans section has been great..But as a R33 4 door owner and i think i speak for other Skyline sedan people 32s and 34s we are growing in numbers. A seperate Skyline sedan section or subforum woulb be fantastic. Would this be posible. as you are thinking of changing the sections around....
Its hard to justify a seperate section for just 4 door variants of skylines... I mean a vast majority of the car is the same as a coupe. Stageas and Cefiros are completely different models, so seperate sections for them are somewhat justified.
That said, the reason I originally named the section Cefiro and RB Powered Sedans was so that 4 door Skyline owners had somewhere to post about bodykits that were unique to them and about this newfangled thing called rear doors and windows.
I guess with the new naming of the section we just have to hope that 4 door skyline owners identify themselves as owners of a Taxi :)
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
