6x r34 gtr Vspec conrods less than 25,000k's use removed from working engine. $350.
6x gtr rods age unknown $300 for the set will seperate.
2x R32 GTR Turbo's in perfect working order no damage $150 each sold
3x damaged r32 gtr turbo's 2x exhaust wheel damage 1x exhaust shaft snapped. $30 each
3x R32 GTR Dumps standard $10 each
Atmo bov $50
R34 GTR Diff Centre and Output Shafts $800
Old School 6 point saftey harnes pair. (brand new never used munufactured 1992) $100
R33 GTR Tail Lights pair $150
R33 GTR Rear Tower Brace $100
R33 GTR Rear Interior (rear seats side panels) $600
R32 Rear Bumper $70
R33 (gtr) Antenna and motor $70
R33 (gtr) Rear Bumper, Bumper Support and Skyline pannel $150
R33 Seat Belt Set of 4 ADR Approved Belts $100 Per pair $200 fullset
RB20 Head working perfectly with covers no coils $300
RB20 Short motor PERFECT Bores and bottom end no sump $300
Rb20det Tomei ECU $450
2x 5 dial SAFC's $100 each. (sold)
pair of alcon calipers $800 PN: AL6346A306J CAL6346A306F
Edited by driftstore
https://www.sau.com.au/forums/topic/121159-gtr-rb26-assorted-parts/
  • 1 month later...
can you Pm me more pictures of calipers, preferably the inside and mounting blocks. do you have model no's and piston sizes, hole distances, pads part no, history, etc, etc.
thanks
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
