Hey, I have a Genuine R32 GTR front bar for sale. Slight tow ball damage from a Hilux :) . Is fixable I'm told. $150 ono. I've ordered my full BN kit so no need for it. If anyone wants it, make me a offer, very negotiabe.
In W.A - Will ship on buyers expense.
PM me on here. Thanks
Jason.
https://www.sau.com.au/forums/topic/121241-fs-r32-gtr-front-bar/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
