! Price Drop ! Intercooler Piping Kits In Stock To Suit All Major Jap Cars! Only $249
BUY FROM A TRUSTED TRADER!!!
Complete Front mount intercooler piping kits to suit all Major jap cars
Excluding CA18DET
ONLY $249 - LIMITED STOCKS
The gktech front mount intercooler piping kits are constructed entirely of high quality 6061 aluminum. The piping is all mandrel bent and contains minimal weld marks throughout the whole kit. The kit includes all brackets, nuts, bolts, tripple layer silicon hoses, clamps etc. These kits are to suit an intercooler measuring 600mm long and to have 3" end tanks.
The kits are designed to be installed DIY and are very easy. For installation help please email us or give us a call.
Features & Specs:
-2.5" Mandrel bent aluminium
-100% polished piping
-Heavy Duty clamps
-All brackets are included
-Tripple layer silicon hoses
-To suit Inlet/Outlet: 3inch
-Great fitment every time
FREIGHT: (all items are sent out by registered post with full insurance)
VIC: $20
SA/NSW: $30
QLD: $35
WA/NT: $40
IN STOCK NOW READY TO BE SENT OUT OR PICKED UP!!!
To order please send me a PM or send an email to [email protected]
im after a one for a R32. for these kits how many holes do i have to cut?
Hi mate, only one hole needs to be cut in the drivers side just below the battery tray.
If there's anything else I can help you with please let me know.
cheers,
Greg
Any modifications need to be done for an r34 Gt-T??
THe R34 GT-T kit requires one hole to be cut in the drivers side. Apart from that it really is bolt on and quite easy to do.
PM me or email us if you wish to order.
cheers,
Greg
We've still got a fair few of the skyline kits in stock.
We can also do the full intercooler kit for only $349 now!!
Are you able to give me the measurement for the cheap R34 FMIC? Is it 80mm thick?
Hi mate, and sorry for the slow reply. For some reason all the SAU emails have been going to the junkbox.
The intercooler for all the kits measure 600*300*76mm.
The price for the full kit is now $349 for forum members, or if you're just after the piping kit the price is now $199.
cheers,
Greg
awesome kit for the price
fit up nicely, didnt have to cut the engine fan fins
took 4 hrs
hardest part was cutting the hole and grinding off the chassis nose
otherwise its excellent
noticed big power difference
took 4 hrs
Thanks mate, it was a pleasure doing business with you.
If there's anything I can help you with in the future, please feel free to contact me.
cheers,
Greg
How is the piping run in this kit under the cooler?(on R32)
Hi mate, it is the same design as the 33's.
It runs from the passengers side to the drivers side, through the wheel arch (under the battery tray on the R32's) and then up past the radiator to the throttle body pipe.
If you'd like some pictures, please PM me or send us an email.
cheers,
Greg
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
