Comments Engine mods;....
Twin 600hp turbos, high mount
Single sub zero external waste gate, with high tension spring
Custom manifold, dump pipes ( ceramic coated)
All speed flow fittings
Rampod filters
Arp oversized head studs
custom intercooler piping
4" intercooler
Blitz and HKS blow off valves
Tomei top end, cams, buckets, double valve springs, vernier cam gears, timing belt, head gasket
ported and polished head
n1 water pump
nismo oil pump
n1 harmonic balancer
1000cc injectors
adjustable regulator
custom surge tank
dual fuel lines from bosch pumps to custom rail, all speed flow fittings
speed flow fuel filters
forge rods and pistons
hks oil cooler
custom oil sepparator breather
triple plate clutch
dual 3.5" exhaust from turbo
m&w igniters, with 6 single coils
EMS computer recently up graded
sparco radiator hoses
Interior;..........
Nissmo 320kmph speedo (white)
Nissmo centre gauges (white)
Nissmo short shifter
Sports steering wheel and gear knob
Carbon fiber dash cover
Alpine speakers
Turbo smart 60psi boost controler
Trust turbo timer
Apexi boost gauge electronic
Apexi fuel gauge electronic
Exterior;......
Blitz 17" wheels
Olins suspension, lowered
Original Veilside body kit (standard front bar, and spoiler)
Optional extras, (negotiated cost);........
Full roll cage
Veilside spoiler and front bar
Standard valve springs, cams and cam gears
Standard instrument cluster
Carbon fibre bonnet (not the cheap stuff)
Carbon fibre boot (not the cheap stuff)
Power;.........
Currently dynoed at just over 460kw at the wheels, on a low boost setting,with mid octane level pump fuel,with a mild tune, built to run over 35psi and rev to 10,500rpm.
Expected power of well over 520kw to 550kw at the wheels
Definately not for the faint hearted.
No problem driving everday as well as weekend racer
Big dollars spent, immaculate condition.. $49,000
serious offers considered
no dreamers, test pilots wanabes or stupid offers please
Edited by luvsit
Oh.... my... god..
That thing is an absolute sex machine. I think I'm in love!
Officially the meanest R33 I have ever laid eyes on.
Good luck with the sale, and I pray this goes to a good home!
Oh.... my... god..
thanks champ, its my pride and joy
Edited by luvsit
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
