where u get them from lee? how much?
hey Brad, i got them thru my mate (he used to work at 1 of the import places) he had them just in his garage haha ... hes got all kinds of random stuff he also fitted red LED's in them (apparently very hard to find, also from Japan, they look awesome!!) . I dont know where he got the clear sides from but wouldnt suprise me if he had more ...i'll ask him for ya :P
oh and price...FREE!!!!! :D
Edited by STAGE-A
  • Replies 110
if the front bar indicators are the same for 260rs ..Lens #3233 ..then put me down for a pair
where do i send the money? :D
not sure if theyre the same. pop one out and take a photo. If theyre the sames, its only one screw so its not difficult.
What IS difficult is getting sellers to come to the party with having the quantity we need and not being c*cks...
Just letting you know:
I can get 10 sets of Genuine NISMO side repeaters for $50 delivered.
Let me know if you want them so I can order asap.
:D
both. if you dbl check the first post, it is for frlonts, sides, and even taillights depending on $$$$.
PS performance-wise... 10 sets for $50? so... $5 each...?? lol
Maybe if we are all happy enough to pay that, then awesome.
Like i said earlier - im not concerned where they come from, and who we get them through, it was just an EOI initially. Just a way to save money on something most of us have thought about doing. Orange indicators are a lil bit 80's.
Im just havin dramas finding time and energy atm. 7day weeks...
I sent off a few emails, but just keep getting retards.
haha - $5 a set!! Im a fool :wub:
Im actually trying to source these for even cheaper.
I'll post once I know.
But so far I can definitely get them for $50 delivered.
Need 10 buyers, youve got 8 so far.
Id be more than happy to organise the side indicators but because Im a trader I have to run it in the trader section.
Otherwise, you can arange it through me and arange everyones money and delivery details.
One thing is for sure though.... I will make it happen and I can get it rolling as soon as Ive got the go ahead from you guys :happy:
think weve got 10, hey...
Personally, Im ok with $50, for genuine nismo. I was looking at $20/$30 cheapies, but i figure its not like you replace your indicators often. I you are only gonna buy them once in your lifetime, you may as well fork out an extra $20 and get something decent.
Its just a matter of how much it is going to cost in the end, and whether ppl are happy to pay it.
$50 eh, yeah I would be in for that, they are the side ones right?
Correct. They are for teh sides.
The fronts are easy, as its just a plastic housing from an altima. Exact same mould as stagea indicators, cept they are clear, and altima's use them as parker lights.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
