I finally got my car back on the road after 3 weeks (after waiting for my new clutch to arrive, then trying to source a second hand flywheel, waiting for that to get machined then get put back together)
Basically I got it back on Friday and everything was fine. Ive driven it real gently to bed the clutch in.
The next day as I drive up my driveway the car cuts out and then refuses to start.
Im not sure if the slight bump of going up the kerb has made something electrical lose contact?
I know the workshop would have disconnected the battery when they did the work on the clutch. It turns over ok, so I dont think its the battery. I have tried jump starting it and it made no difference.
Have checked all fuses under the dash, under the hood and in the boot.
The alarm/immobilizer seems to be working as normal.
Disconnected the fuel hose and turned it over and plenty of fuel is flowing.
Have disconnected and reconnected the battery.
Using standard ECU with SAFCII
1995 R33 GTSt
Also, if it makes any difference, it appears the clock reset back to 12:00 after the car cut out.
Any other ideas?
cheers
Nathan
on ACC on the SAFC check out ETC, SENSOR and do they all have values?
it could the airflow meter tap in has come loose or disconnected which will mean the car will instantly stall as there is no airflow meter signal
you can also try stock ecu diag
The Sensor value on the SAFC show:
In-1: 0.160V
In-2: 0.010V
Thrt: 0.320V
Knk: 00000
AFM plus is connected properly
I tried to do a ecu diag, but cant seem to find the screw to turn, or the LEDs? Theres only one hole to poke a screwdriver and all I can see is IC further inside, ie nothing to turn.
Unless I have some wierd ecu? :wave:
screw and leds is 1986 style
the newer ones i dont think have screw and leds
you need diag cable
You just need to bridge two terminals on the diagnostic link and it will flash the codes on the dash.
Anyone know where the diagnostic port is on a series 1.5 R33?
One post said it should be near the fuse panel.
It tried this, and behind the kick panel and even removed the lower part of the dash board but still cant seem to see it :)
Is it clearly obvious in the pic?
The engine warning light will flash on the warnign panel
1995 R33 GTSt
Any other ideas?
cheers
Nathan
Had the identical thing happen to me in my old VL (RB30E engine) while I was driving along the Gold Coast Hway on the Gold Coast (Duh!).
It was my CAS (Crank Angle Sensor). The car would turn over fine, everything worked, it just wouldn't start. Check your CAS, it might just be that :D
Hope that helps mate. Good luck.
Ben.
It was my CAS (Crank Angle Sensor). The car would turn over fine, everything worked, it just wouldn't start. Check your CAS, it might just be that :rofl:
Ben.
Hill Billy
Run ECU diagnostic and this will tell you if its your crank angle sensor... ( CODE #11 )
Now how to do it. ( HAVE ATTACHED A FEW PICS )
Find that gray plug near the fuse box. I have selected the two wires on picture below you need to short out FOR TWO SECONDS WHILE IGNITION IS ON (car not runing) With a paper clip or a wire.
*FIND PLUG
*TURN ON IGNITION
*SHORT OUT THE WIRES FOR APROX 2 SECONDS ( BLUE & BROWN, right next to each other, left corner )
*WATCH ENGINE LIGHT ON DASH
This will set the ECU in diagnostic mode and run a 55 sensor read out. Codes can be found here on the forum
IF the light flashs 5 times SLOW and 5 times FAST then thats a big OK 55 read out.
Hope that helps... :D
Cheers,
Alex.
Edited by 217/r33
Thanks for the instructions Alex.
Yes it was the CAS.
It just wasnt connected properly. I probably didnt let it click in when I was setting the timing on my cam gear about 6 months ago.
i cant believe it took that long for the connector to come loose.
At least it was free to fix
thanks guys :devil:
Yes it was the CAS.
thanks guys :devil:
No worries mate good to hear your problem was an easy fix. :)
:D
Alex.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
